CMoy para el Celular
Notapor toronja_rabiosa » Dom Nov 30, 2014 8:02 pm
Buenas DIYeros... les quiero mostrar el pequeño ampli que arme para el celular...
Me encontré que mi Motorola xt915 conocido como Motorola D1 tiene un sonido muy bajo con cargas inferiores a 32 ohms... teniendo en cuenta que tengo unos auriculares Sony MDR ZX100, los cuales son de 24ohm (creo que toda la linea Sony viene hace unos años con 24 ohms), y con el celular verdaderamente NO SUENAN [-X
Entonces emprendí la búsqueda de un ampli chico (lease portable) y que pueda mover los auriculares... mirando la pagina del CMOY resulta ser que se le pueden conectar otros auriculares Sony de 24 ohms...
En una parte lo muestran bien claro...
Appendix 1: Tweaking the Amp for Low Impedance Headphones
The OPA134 opamp produces a small DC offset voltage, which does not affect the amp’s performance when driving medium to high impedance headphones (over 100 ohms). Low impedance headphones (32 ohms or less) can cause the power supply to become unbalanced, because a small current flows though the load, even when the amp is at idle. This table compares the power supply voltages with the Sennheiser HD600 (300 ohms) and Sony MDR-G52LP (24 ohms) headphones connected to the amp.
Amplifier Load V+ V-
No headphone 3.9V -3.9V
HD600 (300 ohms) 3.9V -3.9V
MDR-G52LP (24 ohms) 4.2V -3.7V
Note: the battery by itself measured 8VDC.
There is disagreement about whether this almost negligible offset is worth the trouble to fix. With opamps other than the OPA134 series, the offset might be higher and the power supply imbalance could be greater. The offset has not damaged any of my headphones, but it might impact performance slightly by reducing the amp’s power output, injecting noise and/or draining the battery. To determine whether a certain headphone unbalances the power supply, measure the V+ and V- values with and without the headphones plugged in (and no music playing).
For those who want to reduce or block the offset current, figure A1 shows two ways to modify the amp for optimal performance with low impedance headphones: a) add a load resistor or b) AC-couple the amp’s output. A third way is to rebuild the power supply with an active virtual ground device like the TLE2426 or an opamp-based equivalent. Active virtual ground circuits are described in the addendum.
Modifying for Low Impedance Headphones.
Figure A1
Solution A is the simplest and allows the output to remain DC coupled. The load resistor (figure A1a) will help stabilize the virtual ground and reduce any hiss or noise in the system. The load resistor does create a voltage divider effect with low impedance headphones, and so may lower the amp’s gain and maximum output power and possibly alter the frequency response. Some say that the pocket amp’s gain of 11 is too high for low impedance headphones, so the small drop in gain due to R5 might be desirable anyway. Choose a R5 value just large enough to stabilize the power supply without too much volume loss. I recommend a 1/4 watt, metal film resistor in the 20-50 ohm range.
Solution B avoids a voltage divider effect because although the capacitor blocks DC current, it is largely invisible to audio frequencies. The circuit in figure A1b shows how to switch between AC-coupled and DC-coupled outputs for the highest fidelity with medium and high impedance headphones (the load resistor in solution A could be switched too). Choose the largest value electrolytic capacitor that will fit in the enclosure. A 220uF capacitor will give a flat response down to about 22Hz in 32-ohm headphones.
Use a high quality, low impedance electrolytic capacitor to minimize any sonic coloration. High quality electrolytic caps don’t have to be expensive. The Nichicon Muse KZ series 470uF, 25V sells for less than $1.00 at the time of this writing. The Panasonic FC and FM series caps are also less than $1.00 each. The exotic Elna Silmic II series (which feature a silk fiber dielectric instead of paper) has a 470uF, 25V unit for less than $2.00 each. By comparison, an ultra high-end type like the Black Gate 470uF, 16V typically sells for around $12.00 each and is not recommended for this amp.
Me puse, lo arme... y fui probando...
Primero una resistencias de 22ohm en la salida y la verdad que sonaba horrible... :-S
Entonces le mande 2 caps de 470uF a la salida y mejoro... :d
Después me encontré con que se des balanceaba la alimentación así que implemente un TLE2426 para generar la tierra... también le puse unos caps al TLE y al OPA para silenciar mas el ampli...
Quedo algo así...
(el diodo en la alimentación es para evitar la cagada de poner la batería al revés)
Sin mediar mas palabras agarre una placa pre perforada y lo arme :D
Imagen Imagen
Despues le conseguí casita (se la "getie" a mi suegro que es tapicero) http://articulo.mercadolibre.com.ar/MLA-528067215-grampas-grapas-stanley-pengrampadora-tr-250-tr200-tr150-_JM
Imagen Imagen
Así quedo terminadito y sonando una bomba... con un consumo promedio de 30mA
Sitios que consulte para armarlo:
http://headwize.com/?page_id=707p
http://diyaudioprojects.com/Chip/CMoy-Grado-RA1-Headphone-Amp/
http://diyaudioprojects.blogspot.com.ar/2006/11/cmoy-mint-tin-headphone-amplifier.html
http://tangentsoft.net/audio/cmoy/tweaks.html
http://tangentsoft.net/elec/vgrounds.html
Los componentes activos los "manguie" en TI... el OPA2132 y el TLE2426
Espero les guste... Saludos
toronja_rabiosa
Re: CMoy para el Celular
Notapor ska_gatotw » Lun Dic 01, 2014 1:13 am
Fenómeno!, eso es rebuscársela como corresponde.
para la próxima (o la V2 de esto): no hace falta convertir la tensión de la batería en una fuente doble, con referenciar a un nivel medio la señal de audio es suficiente.
Fijate en esta página de Pisotones que está explicado (en el diagrama del primer circuito, la parte englobada con línea punteada).
Notapor trapiche » Mié Dic 10, 2014 9:15 am
No probaste con otros operacionales?? ayo estaba por probar uno pero ni por asomo consigo ese opamp
Notapor toronja_rabiosa » Mar Dic 16, 2014 4:01 pm
ska_gatotw escribiste:para la próxima (o la V2 de esto): no hace falta convertir la tensión de la batería en una fuente doble, con referenciar a un nivel medio la señal de audio es suficiente.
el tema de la fuente doble es porque el operacional desbalancea la fuente con resistencias cuando es sometido a cargas con impedancia baja... yo tengo unos auriculares Sony de 24ohms... podrás pasarme un link así chusmeo un poco??
trapiche escribiste:No probaste con otros operacionales?? ayo estaba por probar uno pero ni por asomo consigo ese opamp
en esta web tenes ensayos de diferentes opamps y descripciones (en ingles)
http://tangentsoft.net/audio/opamps.html
Igualmente me lo pedi en TI a los mios :-
toronja_rabiosa
Notapor ska_gatotw » Mar Dic 16, 2014 4:08 pm
toronja_rabiosa escribiste:
Recién caigo en la cuenta que no puse el link...
http://www.pisotones.com/TubeScreamer/circuito.htm
En mi post anterior decía que hay que crear un punto medio de tensión positiva para referenciar la señal de audio, en el tubescreamer se hace con un divisor resistivo que en el primer esquema está englobado en una línea punteada, también por ahí está mucho mejor explicado de lo que pueda llegar a hacerlo yo.
Notapor toronja_rabiosa » Mar Dic 16, 2014 9:50 pm
Claro... en el CMoy original tambien pero esta aclarado que para auriculares de baja impedancia conviene hacer lo que hice para mejorar la respuesta :d
toronja_rabiosa
Notapor ska_gatotw » Mar Dic 16, 2014 10:48 pm
toronja_rabiosa escribiste:Claro... en el CMoy original tambien pero esta aclarado que para auriculares de baja impedancia conviene hacer lo que hice para mejorar la respuesta :d
ahhh eso es otra cosa :d
